- Mute
Sunday
(Last edited
Monday
by
SamsungMatt
) in
Hi,
I see there is an intention from Samsung not to solve that issue, it is been open for over 4 years
I own a55 with the latest software and still face the issue
I can see that Samsung is forcing its app, but the auto correction and Samsung algorithm is weak compared to Google
And really the sound disturbs my privacy
So what shall we do?
Solved! Go to Solution.
- Mute
Tuesday (Last edited Tuesday ) in
A Series & Other Mobile- Mark as New
- Mute
Sunday (Last edited Sunday ) in
A Series & Other MobileWhat are you referring to with regard to sound on the G-Board? Key Click sounds? Talk to Text? What? I have been using G-Board for years and years and years. There is no sound, unless you have turned on "sound on keypress" in the G-Board settings. If you are referring to Talk to Text, you should switch to Google Voice typing, which will work with either keyboard. Why should Samsung solve what appears to be a Google problem? Even though whatever you are complaining about is happening with on a Samsung phone, it is still a Google issue.
- Mute
Monday in
A Series & Other MobileI talk about the key press sound and in fact it is a one ui problem it is not related to google as this issue has been on for over 4 years and is focused only in samsung, sammobile talked about it
and there are plenty of complaints about that
- Mute
Monday (Last edited Monday ) in
A Series & Other MobileAre you getting the sound or not getting the sound? You have to turn it on or off in the Gboard settings. Does it really make a difference as long as your words come out? I've never had an issue with it (on or off), nor have I seen other complaints about it, so it's not a OneUI problem, it's a "you" problem, so not Samsung's problem to fix. Even it was a OneUI problem, it would still be Google's problem to fix to make it compatible. Be specific about what your issue is. It may be as simple as uninstalling and reinstalling GBoard.
- Mute
Monday in
A Series & Other MobileI have done all things avilable before this post
the sound level doesn't change it is stuck
and I have uninstalled reinstalled
- Mute
Monday in
- Mute
- Mute
- Mute
Tuesday in
A Series & Other Mobilehow is it a google issue? sorry could you confirm that
this issue has been on for over 4 years and btw there is an app from Samsung called sound assistant if you even assign sound for the Gboard app only it also doesn't work
- Mute
Tuesday in
