Fold 6 and Android Auto Audio streaming
(Topic created: 12-17-2024 01:02 PM)
JaStork
Cosmic Ray
Fold & Flip Phones
I have had a note 20, fold 4, s23 ultra and now recently this fold 6. I've had it for almost a month now and I have noticed android auto performance to stutter/skip when streaming music. This happens with Spotify, Pandora and YouTube music. I have never had a problem with my past phones, this fold 6 os the first I've noticed it. Using in same veh as all the others were used. Latest firmwares on everything.
Has anyone else had a similar problem issue?
Sometime rebooting the fold 6 remedies it for a while but it returns.
Corpo_Muskrat
Fold & Flip Phones
I had the same issue with mine. I bought a better USB C cable and that fixed the issue.
JaStork
Cosmic Ray
Fold & Flip Phones
Well. Perhaps. My unit can do wired and wireless. It still happens on wireless too. Doesn't matter if it's wired or wireless
CAPTAIN85
Cosmic Ray
Fold & Flip Phones
Have you downloaded sound assistant from goodlock? Any audio issue I've ever had with a samsung went away after downloading it. You can also try 'sound quality and effects' in settings and toggle Dolby on or off. Usually fixed things for me too.
ceddes
Fold & Flip Phones
Did you change the audio equalizer? There is currently a bug that causes Google Assistant not to work correctly if it's changed to anything but default on Android Auto.
JaStork
Cosmic Ray
Fold & Flip Phones
No I've never adjusted any of that. It's just crazy. My wife got the new s24 when I got this fold. It works normally as expected.
