Volume on Buds 3 Pro wont really increase past 130 when using custom equilizer
(Topic created: 09-19-2024 09:34 AM)
foog86
Galaxy Buds
Hello, I recently obtained a pair of Buds 3 Pros in white. The volume works fine 0-130, however  beyond it seems to cap itself automatically past that. When increasing to 140 or  150, I can hear louder music before everything in the song is limited to what seems to be a certain loudness. It makes the music sound weird and the only way I could combat this was setting my volume limit to cap at  130 but having the popup annoying with that as well as not being able to have maximum volume was annoying. It does this with Atmos on and off, it does this no matter the sound mode (ambient, anc, default) but doesn't do this if on any of the preset sound profiles. This is incredibly annoying, does anyone know a fix? I'd like to listen to my music in proper volume. I'm also on OneUI 6.1.1 if that matters.
27414
Galaxy Buds
I got the power app equalizer. Loudest of them all. And I've tried them all.
foog86
Galaxy Buds
The problem with that is that it still is the same weird sounding audio even with volume increasers. It still caps off weirdly at 130 and refuses to go higher in actual volume no matter what I set it to, whether that volume itself is increased or not.
userwiI7aSMY8V
Galaxy Buds
When calling from my sync'd Samsung A51 5 G phone, I can hear the voice of whom I am calling, but they can't hear me. Does anyone have a solution -- TIA
Galaxy Buds
No bro no caps. Trust me I know what u are talking about. Try the power app equalizer on Google Play. Trust me . I'm a music engineer in DFW trust me
Galaxy Buds
Trust me . It helps u go inside your phone and change the Bluetooth system for better song. I promise u will get lost with and the things it has.
foog86
Galaxy Buds
Do you have a link to it? I cannot find it via search on the play store
Galaxy Buds
I got a 2013 Kia. People swear I have a system. No factory
Galaxy Buds
I try to swear to . It's on Google
Galaxy Buds
