Nattyttan
- Mute
a month ago (Last edited 3 weeks ago by SamsungJoJo ) in
Galaxy Note PhonesNote 8 black screen has charging light working and when u turn on it vibrates and u can turn volume up and down but nothing on screen
Do I need a new screen
meself
Neutron Star
- Mute
a month ago in
Galaxy Note Phones
Would think screen is malfunctioning could of gone bad or you have a bad issue on the phone
Robin621k
Honored Contributor
- Mute
a month ago in
Galaxy Note Phones
The Note 8 was released in 2017, it is a 7 yr old phone that receives no more software support. Apps will no longer work on that device soon.
Even if you bought the kit to replace the screen it will be $200 to fix it with reputable replacement parts. Probably needs a new battery too.
It might be time to get a new phone.
polymatrix
Cosmic Ray
- Mute
a month ago in
Galaxy Note Phones
Agree with Robin. There's great deals on gently used phones for less than $200. You can get a good bang for your buck on the A-series models too, if you're not looking for the Note/Ultra style experience.
BlueSkies
Nebula
- Mute
4 weeks ago in
Galaxy Note Phones
I also agree with Robin. If you're willing to get a new screen which is going to be expensive. I rather recommend you to just buy a new phone that should be getting the latest updates.
