PIN LOCK is does not recognize my PIN and face recognition is not working
(Topic created: 03-18-2020 12:59 AM)
usersSzgPo928B
Galaxy Note Phones
SamsungAdam
Galaxy Note Phones
Do you have Find My Mobile set up on your device?
-Lost your phone?
-Don't panic. Find My Mobile will help you locate your phone or tablet and protect your data. You can even use it to unlock if you forget your pattern, -   PIN, or password.
*To use this service, you must be signed in to your Samsung Account on your device.
Since smartphones have become an essential part of our lives, the ‘Find My Mobile’ service can be a necessary preventive measure against the loss of your smartphone. If you have lost your device, try the ‘Find My Mobile’ service. You can remotely locate your lost smartphone, back up data stored on the device to Samsung Cloud, lock the screen, and even block access to Samsung Pay. You can also delete all data stored on your device.
Give this link a try to remotely unlocking your device: https://findmymobile.samsung.com/
1 Reply
SamsungAdam
Galaxy Note Phones
-Lost your phone?
