Battery Issues
(Topic created: 3 weeks ago)
AceTrader
Galaxy Ring
Recently started to have battery Issues. Ring discharges fully from 100% in about 3 hours. Support doesn't seem to know the difference between a watch and ring with suggestions to adjust screen brightness, disable wifi, disable nfc, etc.
Only option is for mail in repair. No device for weeks.
Robin621k
Honored Contributor
Galaxy Ring
Did you try a reset of the ring first?
If that doesn't work, your only choice is to send it in. They can't be repaired, only replaced upon warranty.
AceTrader
Galaxy Ring
Yes, I've reset it a few times.
Robin621k
Honored Contributor
Galaxy Ring
You have to call and get a ticket made and send it in.
