Samsung s20 ultra dropping WiFi connection constantly
(Topic created: 04-08-2020 10:51 AM)
user68dGQIWk58
Galaxy S Phones
Had new Samsung galaxy s20 ultra less than a week now and it constantly drops WiFi connection at home. Cannot reconnect without rebooting phone.
Samsung knows of this issue but no fix. Cannot get to speak to anyone for support due to Covid-19.
Now want to return the phone but again cannot contact anyone to sort return.
What do I do??
JUMP TO SOLUTION
seraph973
Galaxy S Phones
oddly enough, this worked for me. when the location services is turned off the apps that use it does not cause my wifi to drop. then tried turning it on and wifi dropped again when using apps that use location
OllyW
Galaxy S Phones
I had the same problem on my S20 plus and this worked for me too.
bpa
Galaxy S Phones
I just started having the same problem since I switched out my router for a Google Wifi. I had a Linksys before and never any issue. I now have a mesh with 2 points, phone is mostly on 2,4Ghz and never looses the connection itself but no data is send or received. Apps just hang for 15 secs or more and than it starts working again. At times I need to disable and reenable wifi to get it going again. I have about 20 other devices that have zero problems including a S9,S10 and A50.
update:
I disabled the "Google Location Accuracy" in settings and this seems to have cured to problem completely.
update2:
latest Samsung update has fixed the issues. Thanks !
usergkWHt0YnLO
Galaxy S Phones
Just started encountering the same issue just after updating to Android 11 and OneUI 3.0.  Thos is ridiculous. Modem and router not the issue.
vidal_asuncion
Galaxy S Phones
Hello, same issue here. My wifi icon gets an exclamation mark, and my phone can't get access to internet. When I go to wifi settings, looks like my phone get wifi access again. If I check my router dashboard when the exclamation symbol appears, I can't see the phone connected to the wifi. Any help please! I think this is an expensive phone, I can't believe that we have this kind of problems.
Galaxy S Phones
try download samsung members app and submit a ticket.
once you open, click +, then click error report
there should be a category for wifi you can choose from.
userzjlBT0bYHD
Galaxy S Phones
Hi, if the following is true for you, then the solution which worked for me should work for you too. If you have a mesh network / multiple access points with the same WiFi SSID / dual band network with single SSID, simply disabling Google Location Accuracy in Settings > Location will work. If not, I also have WiFi scanning disabled in Settings > Location > Improve Accuracy.
Hopefully it works for you and ends the nightmare.
I've contacted Samsung twice now and advised that this solved my problem so if it solves yours too, please comment so it is escalated as something to fix. It seems to only affect Samsung phones of S10 and above.
userDPhtjVgEPW
Galaxy S Phones
Thanks, totally worked for us.
We tried so many things ... we replaced the sim-card, launched the phone is safe-mode as support told us ... but finally ... disabling the google location improvement service solved the issues.
userbKudWuYRrh
Galaxy S Phones
This works!!!! I made an account just to say that and to say thanks!! Its been over an hour and my wifi hasn't dropped! My wifi started dropping as soon as I got the update a few days ago. Tried a new router, didn't work. Oddly, wifi did not drop at my sister's house.
userv8eYOtRzN3
Galaxy S Phones
Thanks! This one works.
