Audio output switch option disappeared
(Topic created: 05-03-2022 04:37 PM)
Badvik83
Galaxy Note Phones
The audio output selection option has disappeared from the top menu. How do I restore it? Can't find it anywhere. Thank you
Who_Dis
Neutron Star
Galaxy Note Phones
the smart things audio output selection in the quick panel notification is gone now.. you need to use the Media Output button that is default to the quick panel
Samsung_Moderator
Galaxy Note Phones
Hello, thank you for your feedback. I realize how complicated this has made things for you. I am including a link to a guide to support your concerns on changing your quick panel settings https://www.samsung.com/us/support/answer/ANS00062651/
Badvik83
Galaxy Note Phones
Thank you, but this guide doesn't explain how to bring SmartThings Audio output back
usereI3dZFCLYX
Galaxy Note Phones
I've been having this issue as well since updating yesterday
Who_Dis
Neutron Star
Galaxy Note Phones
