S22 ultra Bluetooth volume too low
(Topic created: 01-29-2024 01:59 PM)
Truthseeker501
Galaxy S22
S22 Ultra Bluetooth volume too low and volume limit won't reset. Tired 3 different ways as recommended on YouTube, with no results. Hearing protection/ volume limiter slide bar does not work...Plz help...!
Samsung_Moderator
Galaxy S22
Hello! I can certainly understand how frustrating it is when your volume is too low! I would suggest clearing the cache of the device by following the below steps
With the device off, press and hold the Volume Up key first, then the Side key.
When the Android logo displays, release all keys and wait until you get the Android system recovery menu options.
Press Volume down to highlight Wipe cache partition, then press Side key to select it.
If you're still having the same issue I would then try backing up your device and doing a factory data reset by following these steps.
Navigate to and open Settings, and then tap General management. Swipe to and tap Reset, and then tap Reset all settings. Review the information, and then tap Reset settings. Tap Reset to confirm.
You can also submit an error report by going to the Samsung Members app > Get help > Send feedback > Error reports.
I hope this helps!
Truthseeker501
Galaxy S22
Samsung I'm STILL WAITING ON THE FIX...ON BLUETOOTH Headphones devices, Media Volume Limit and Custom Volume Limit sliders WONT ADJUST, VOLUME TOO LOW ! Unpaired then repaired devices, restarted phone didn't WORK šŸ¤”šŸ˜”
Samsung_Moderator
Galaxy S22
I hope this helps!
alberteugene
Galaxy S22
I'm really disappointed with my s24 ultra bought on Dec 4th. and the lack of support. I cannot recommend this phone to anyone.
