Need help with a issue with my video recording on my S23 Ultra.
(Topic created: 05-26-2024 02:04 PM)
Captainjack5530
Galaxy S23
I this picture you will see the place I am asking about. The problem is I can't change this. And when I try to it says can't change because of current ratio.
So I am asking if someone can help explain to me why this is and what is it talking about and how to fix this to where I can change it!?!
GaryB82
Galactic Samsung Care Ambassador
Galaxy S23
You have to select Full and change it to 9:16 is the only one you can record 30 frames in.
If you've found my post to be helpful, Please like my Comments ✓✓✓.
If my response resolved your issue, please press the Like and ✓✓✓ to Accept as Solution button.
SlapsRUS
Galaxy S23
Have you tried clicking the option that says "Full"?
Captainjack5530
Galaxy S23
That worked thank you.
GaryB82
Galaxy S23
Captainjack5530
Galaxy S23
No I never would have thought of that! I thought that was for you to have the choice to use all of you screen or not. But it worked. Thank you for your help with this.
chonkeymonkey
Galaxy S23
U get good
coldengrey
Galaxy S23
Now, I've got UHD 4K 60fps Vids I've shot in Pro Mode >
AM I INCORRECT that FULL ratio, UHD 4k, was ONCE POSSIBLE IN 30/60FPS optimal light!?
I, now, must film in 16:9 or drop to FHD Resolution with 60fps keeping Full Ratio.
Was this a confirmed downgrade or change after updates...
Or is the Advanced Camera Settings App, from Galaxy Store something to do with an odd setting I don't understand?
