Contact storage draining battery and causing overheating issue on S24 ultra
(Topic created: 03-27-2025 01:35 PM)
Mirza91
Galaxy S24
 contact storage is draining battery and causing overheating issue everyday. Tried restricting battery, force stop, power saving mode, performance profile light, refresh rate 60fps, FHD display, no dual messenger using. Using dual sim. Still no solution.
realaud
Honored Contributor
Galaxy S24
Where are you storing your contacts, on the phone, in your Samsung account, or in Google? Contacts storage should not use any battery power at all.
Please mark any response that helped you as your solution.
Samsung_Moderator
Galaxy S24
Hello Mirza91, Welcome to the Community. We understand the concern with the Contacts Storage draining the battery.
Have you tried optimizing the battery through Device Care? This article provides the steps, as well as additional suggestions to save battery time. https://www.samsung.com/us/support/galaxy-battery/optimization/
Be sure the Personal Data Intelligence app (and all apps) is fully updated.
Additionally, try clearing the cache partition. To get to recovery mode:
- Turn off phone
- Once off, hold down volume up and power buttons simultaneously
- When Samsung logo appears, release power button BUT KEEP HOLDING VOLUME UP until the recovery menu appears
- Use volume buttons to navigate down to clear cache (NOT CLEAR DATA/ FACTORY RESET)
- Use power button to select.
For the overheating, you can try these steps: https://www.samsung.com/us/support/answer/ANS10002887/
We also recommend submitting an error report to provide the information to Samsung. https://us.community.samsung.com/t5/Tips-Tricks/How-to-Submit-an-Error-Report/ba-p/3001692
If you've tried troubleshooting above, when it comes to exorbitant drain to the battery and overheating, repairs would be recommended. You can use the following link to set up service in the U.S.: http://www.samsung.com/us/support/service/
For international customers, please use this link: https://www.samsung.com/us/common/visitlocationsite.html
