Incoming calls not connecting
(Topic created: 09-29-2024 10:17 AM)
svogtle
Galaxy S24
Incoming calls do not always connect, my phone doesn't ring. Some of these calls go to voicemail while others do not & don't appear as "recent". Other times my phone rings just fine.
I haven't been able to chat with my carrier as the code they're sending to my phone never shows up. I will head to a Verizon store if this avenue doesn't help.
realaud
Honored Contributor
Galaxy S24
This is a carrier issue.
realaud
Honored Contributor
Galaxy S24
PghLei
Galaxy
Galaxy S24
Mine does the same, my watch will ring but not my phone. Happens often too
Emptybucket
Galaxy S24
Mine does too, are you on Verizon?
xraystacy
Galaxy S24
My husband is unable to ring through to my phone - it goes straight to voicemail but his texts come through just fine.
thibo
Galaxy S24
Same here got 3 calls 1 did nothing ,2 one budy ,an 3rd one worked,,why
