Bluetooth sound switching between BT speaker and phone speaker
(Topic created: 03-07-2025 11:08 AM)
JohnC77777777
Cosmic Ray
Galaxy S25
S25 ultra. My Bluetooth is connecting fine to my Bluetooth speaker, but every now and then the sound stops coming out of my Bluetooth speaker on my desk and switches to the handset (S25) speaker. The Bluetooth is still connected it is just that the sound is coming out of the handset. If I turn the Bluetooth off and then turn it back on the sound moves back over to the Bluetooth. I have tried this with a case and without a case and no changes. It has also happened both with my Bluetooth speaker on my desk and in the car, so I know it is not a problem with the Bluetooth unit, but has to be something in the phone.
Does anybody have any thoughts?
jppanucci
Cosmic Ray
Galaxy S25
Attempt modifying the Bluetooth AVRCP version within the developer options; the speaker may only support a specific version.1741375273645.jpg
JohnC77777777
Cosmic Ray
Galaxy S25
Will give it a shot. Thanks.
JohnC77777777
Cosmic Ray
Galaxy S25
I've ccled through all 4 options and still happening.
Any other suggestions would be appreciated.
SamsungMod
Galaxy S25
Hello JohnC77777777, Welcome and thank you for being part of the Community. We understand how frustrating it is to have the audio cycle between the devices.
Have you tried resetting the Bluetooth settings? Phone settings>General Management>Reset>Reset Wi-Fi and Bluetooth settings (You will have to reconnect to these devices after the reset.)
Let us know if this helps.
JohnC77777777
Cosmic Ray
Galaxy S25
Cycled
JohnC77777777
Cosmic Ray
Galaxy S25
I'll give the reset a try. I think I may have done it already but not sure.
CarloMonterrey
Galaxy S25
My bluetooth is samsung s15 can connect UBL FLIP 5šŸ™
JohnC77777777
Cosmic Ray
Galaxy S25
So got a new phone from AT&T and set it up clean (didn't transfer over any apps or settings). Still the same issue. This is clearly a software problem.
