- Mute
4 hours ago (Last edited 4 hours ago ) in
Galaxy S25Hello all
It's been a month since I've been using the regular Samsung S25, not the Ultra version, and I've noticed a drop in battery life that I don't like. I've followed all the suggested instructions to save battery life and still haven't seen any improvements (ram plus off, aod, dark mode, 60hz, adaptive battery, light performance, clear cache partition, deep sleep, gps and sync only on selected apps, etc.). When I did a factory reset, the battery changed a bit for the better for two days, but later the battery was draining again as before. Please give me a suggestion on what to do?
Should I charge it to 100% or follow the 20-80% rule?
How much should the screen on time be for a new s25 phone with a 4000amph battery? (currently the screen on time on my phone for a 100% charge is 5 hours, while it is advertised on the internet that it should be 9-11 hours)
Do I need to calibrate the battery?
thanks
ā
- Mute
3 hours ago (Last edited 3 hours ago ) in
Galaxy S25
