- Mute
ā02-22-2025 12:32 AM in
Galaxy S25- When using camera, while using ultra wide lens, its vibrating and making noise
- I think its the focus motor
- Anybody facing noise with vibration while using ultra wide camera in S25 ultra?
- My model is Samsung S25 ultra 512GB
- Mute
ā03-06-2025 12:10 PM in
Galaxy S25Mine is doing the same. It clicks and acts a bit crazy.
- Mute
ā03-01-2025
01:09 PM
(Last edited
ā03-06-2025
01:54 PM
by
SamsungRei
) in
So I've been having this problem with my camera straight out of the box when I received my s25 ultra, everh time i open the camera app the camera jitters in and out and make a loud noice even when zooming in and out i can sometimes get q clear picture but its very annoying to have to wait minutes for my camera to fix itself every time, has anyone else experienced this? Mine always does it? It doesn't let me upload videos so all I have is a picture
- Mute
ā03-01-2025 01:15 PM in
Galaxy S25- Mark as New
- Mute
ā03-01-2025 05:40 PM in
- Mute
3 weeks ago in
- Mute
ā03-01-2025 08:22 PM in
- Mute
ā03-04-2025 01:00 AM in
Galaxy S25I think it might be a software issue. Mine was fine out of the box for the first couple weeks until they rolled out the last software update. Then I started having the same thing happen, but it's not always so I'm fine with waiting for the next software update to see if it gets fixed.
- Mute
ā03-25-2025 01:39 PM in
Galaxy S25It is not an software issue. It is definitely a manufacturing defect
- Mute
4 weeks ago in
Galaxy S25Its actually a software issue, because since s25 ultra has a good ultra wide lens, the phone tries to use that when object is near to the device. Some times the phone get confused about which one to use and then it makes this issues. But with software update i think the switching lens will be stable and fix this issue
