Spacefit sound pro
(Topic created: 11-26-2024 12:36 AM)
Mickeysdad
Home Theater
Recently bought an q990d sound bar to use with s95b samsung tv. Trying to find spacefit soud pro on tv setting and the option is not available.
Samsung_Moderator
Home Theater
Hello @Mickeysdad! Thank you for reaching out! From the information that I could find, the issue is a compatibility issue. The soundbar does support this, but the TV is not compatible. Only 2021 - 2024 QLED Q70 TVs and above are compatible. I have seen some sources say that your TV is compatible with space-fit light, but it's not from a Samsung source, so I can not confirm this. But even this would have some issues not working. Here is the link to the information about the compatible devices.
https://www.samsung.com/au/support/tv-audio-video/use-spacefit-sound/
1 Reply
Samsung_Moderator
Home Theater
