Cleaning small pieces of vegetables from front of vegetable drawers
(Topic created: 04-21-2022 06:24 PM)
uservqLcbLzLB6
Kitchen and Family Hub
I have a 3 door Samsung refrigerator, RF2220NCTASR/AA.  The bottom of the vegetable drawer fronts overlap with the bottom of the drawer so that small pieces of vegetables - seeds, onion skins get stuck between the 2 layers. There is no way to use water to force them out due to the way they overlap. Is there a way to pull the front off of the drawer so that I can clean it? It seems like a design flaw.
Samsung_Moderator
Hi there! Thanks so much for asking about this. I have a couple links I believe can help with this. The first link has detailed information about all the best ways to clean your refrigerator. The second link has step by step instructions on how to remove any of the drawer and bins.
1. https://www.samsung.com/us/support/answer/ANS00079481/
2. https://www.samsung.com/us/support/answer/ANS00063107/
1 Reply
Samsung_Moderator
