- Mute
ā11-11-2024
03:54 PM
(Last edited
a month ago
by
Samsung_Stephan
My Samsung side by side refrigerator will not start after power loss - will read error and we have to manually reset to get it to started. Just installed a designated electrical line ,12-2, on 20amp breaker. Still will not start without showing error message. Any ideas?
- Mute
ā11-11-2024 04:14 PM in
Kitchen and Family HubWhatās the model number and error code
If you've found my post to be helpful, Please like my Comments āāā.
If my response resolved your issue, please press the Like and āāā to Accept as Solution button.
- Mute
ā11-11-2024 04:47 PM in
Kitchen and Family Hub@Maypearl It's very possible that the power loss caused a spike or surge which damaged the refrigerator.
- Mute
ā11-12-2024 01:01 AM in
Kitchen and Family HubHello and welcome to the community!
My first thought would be that the fuse might be bad. Have someone from Samsung come out and check it out if it's still under warranty. Else you might have to replace on your own.
Samsung refrigerators have thermal fuses in the control panel.
Depending on the make and model, the location of the control panel may vary. In most models, the fuse is located inside the back panel in the refrigerator. You will have to remove the back panel cover to gain access to the fuse. The fuse will be attached to the connector assembly on the top. The thermal fuse is usually behind the coil, and you can pull it out.
Slide off the fuse by pulling the connector tabs. If it is damaged, you can replace the unit with a new fuse, put it back into place, and power up the refrigerator.
