Seal/gasket for beverage centre door
(Topic created: 03-19-2024 12:41 AM)
TomEastLdn
Kitchen and Family Hub
Hi I’ve recently discovered that my fridge was delivered without a seal on the small beverage centre door, not only increasing costs to keep it cool but causing a cold draft into my kitchen and increasing my energy costs (not ideal given a cost of living crisis and global warming).  I have chatted to support but they were unable to help (as usual) as they considered this an out of warranty issue.  They did not share the part number, only potential stockists and I can’t find the part anywhere.  The seal seems to be a lot shallower than the main door seals.  Can anybody help?
Samsung fridge  RF65A977FB1/EU (RF9000 Family Hub French Style Fridge Freezer with Beverage Centre)
Samsung_Moderator
Hello! Thank you for reaching out! You can try our part's website samsungparts.com and enter your model number their to find parts. But as this is a UK model from the model provided I would recommend reaching out to your countries support team using the following link: https://www.samsung.com/us/common/visitlocationsite.html
TomEastLdn
Surly with the amount of fridges with beverage centers someone must know?  Is there a universal fitting even I could try? It seems a lot more low profile than regular rubber seals/gaskets?
Samsung_Moderator
