- Mute
3 weeks ago in
Kitchen and Family Hubam unable to get my new refrigrator Smart Side-by-Side Refrigerator (RS28A500ASG) connect to wifi it always says "Error Code 15-200" tried everything nothing works any help appreciated
- Mute
3 weeks ago in
Kitchen and Family Hub- Mark as New
- Mute
3 weeks ago in
Kitchen and Family Hubam using wpa2 using comcast (xfinty standard router ) i have samsung electric range infact thar works perfectly but the fridge am unable to make it work
- Mute
3 weeks ago in
- Mute
3 weeks ago in
Kitchen and Family Hubyes tried rebooting router ,fridge, phone . Even tried to split band between 2.4 and 5 GHZ nothing helped finally ended getting this "Error Code 15-200"
- Mute
3 weeks ago in
Kitchen and Family HubYou have the phone your using to pair it to the app on the same wifi you want to use right during the pairing process? And your phone is up to date software wise as well?
For improved performance, the SmartThings app is subject to change without notice or discontinued support according to the manufacturer’s policy. • Recommended encryption systems include WPA/TKIP and WPA2/AES. Any newer or non-standard Wi-Fi authentication protocols are not supported. • Wireless networks may be affected by the surrounding wireless communication environment. • If your Internet service provider has registered the MAC address of your PC or modem for identification, your Samsung Smart Refrigerator may fail to connect to the Internet. If this happens, contact your Internet service provider for technical assistance. • The firewall settings of your network system may prevent your Samsung Smart Refrigerator from accessing the Internet. Contact your Internet service provider for technical assistance. If this symptom continues, contact a local Samsung service center or retailer. • To configure the wireless access point (AP) settings, see the user manual of the AP (router). • Samsung Smart Refrigerators support IEEE 802.11 b/g/n (2.4 GHz) protocols. (IEEE 802.11 n is recommended.) • Unauthorized Wi-Fi wireless routers may fail to connect to applicable Samsung Smart Refrigerators.
