65" Samsung - Wont reset, wont load apps, cant load support.
(Topic created: 09-19-2024 02:25 PM)
Reedsong
LED and OLED TVs
I deleted every single app. The only thing that will load is the Samsung tv channels. I can't reset anything. If I click on reset smart or any reset it just does nothing. I don't know what to do.
Samsung_Moderator
LED and OLED TVs
Hello @Reedsong! Thank you for reaching out! I would recommend attempting the information in the following link:https://www.samsung.com/us/support/answer/ANS00077524/. If this doesn't help then please call in at 1-800-726-7864 and ask for our remote management team. They will be able to remote into the TV and help reset it!
1 Reply
Samsung_Moderator
LED and OLED TVs
