Tv made a loud pop
(Topic created: 09-21-2024 08:23 PM)
Mytv21
LED and OLED TVs
My 75” Samsung tv made a Loud pop noise and now it won’t turn on. Any idea why this happened.
SamsungTam
Honored Contributor
LED and OLED TVs
Hello! @Mytv21  Thank you for posting about this. I'll be more than delighted to assist you with this. Since you mentioned that the TV is completely off, does any picture show when you turn the remote on? If so, can you navigate through channels if the TV stays on? If the TV doesn't turn on then this unit will need service.
I recommend letting a service technician have a look. As we would like to gather additional information and look at this on a case-by-case basis, please provide the full model code and serial number of the device as well as your best contact phone number, name, and email.
Send a message on Facebook
Send Message on Twitter
Send Message to Moderator
If your unit is out of warranty and you would like to receive quotes on service/labor from an Authorized Service Center near you, please visit:
http://www.samsung.com/us/support/service/location
ChaosSaber
Honored Contributor
LED and OLED TVs
Could be a bad part, bad outlet, surge protector, ect, without actually being in front of it, noone here can tell you why
meself
Honored Contributor
LED and OLED TVs
Could be a circuit or if plugged in to power strip that's gone bad
Mytv21
LED and OLED TVs
I was just watching tv and all of a sudden I heard a sound like a ballon popped and the tv is off. The sound bar still works. The outlet has power just the tv is completely off.
SamsungTam
Honored Contributor
LED and OLED TVs
