Can I use both tv speakers and headset at the same time on my new SAMSUNG UN75CU8000BXZA ?
(Topic created: 12-31-2023 10:28 AM)
cabbottlaw
LED and OLED TVs
Samsung_Moderator
LED and OLED TVs
Hello! Thank you for reaching out! From the model that you have provided you should be able to use the Multi-Output Audio feature. To do this make sure the device is connected. Then go to Settings > All Settings > General & Privacy > Accessibility > Multi-output Audio.
For more information please go to page 148 on your user manual using the link below.
https://downloadcenter.samsung.com/content/UM/202307/20230705133212135/BN81-24055A-410_EM_OSPATSCC_N...
LED and OLED TVs
If you bought and used a 3rd-party Bluetooth connector via the optical audio for example, then yes. Using the onboard Bluetooth, I haven't found a way yet (though I've only tried on 2 models, neither of which are the one you've asked about.)
Samsung_Moderator
LED and OLED TVs
