DU7200 How to listen to TV speakers and Headphones at same time
(Topic created: 10-05-2024 08:16 AM)
bpechtimss
LED and OLED TVs
HELP! I bought a UN50DU7200FXZA and cannot hear both the tv speakers and the headphones at the same time? I plug headphones wireless headphones into the USB port on TV and only headphones work. Is there a way to hear both tv speakers and any wireless headphones at same time? Thank you.
50" Class Crystal UHD DU7200
SamsungTam
Honored Contributor
LED and OLED TVs
Hello! @bpechtimss  Thank you for posting about this. I'll be more than delighted to assist with this issue. Unfortunately, Most Samsung TVs typically do not support simultaneous audio output to internal TV speakers and Bluetooth or wired headphones. You may have to choose one or the other in the sound settings. You can check to see if your model TV has the " Dual audio" feature and you might be able to enable it. Check under Settings> Sound> Sound Output and see if there is an option to output both speakers, Bluetooth, and headphones simultaneously.
You could also use an external Bluetooth transmitter that supports audio pass-through, connecting Bluetooth headphones and speakers to the same output source.
1 Reply
SamsungTam
Honored Contributor
LED and OLED TVs
