- Mute
11-16-2024 10:14 PM in
LED and OLED TVs- Light is leaking from the top and side. The glass is bowing out almost a centimeter at the worst spot on top.
- Some dark spots have shown up because dust and a couple of fruit flies got trapped behind the glass.
- There’s some discoloration at the bottom right edge, probably from pressure on the LCD since the glass isn't being supported evenly.
Solved! Go to Solution.
- Mute
09:48 AM
(Last edited
12-06-2024
11:48 AM
by
SamsungJustin
) in
Hello! Thank you for reaching out! This is something that will require service. Please reach out to Samsung directly in order to get service set up.
You can reach out to one of our moderators
or visit: https://www.samsung.com/us/support/service/
or call 1-800-726-7864
- Mute
09:48 AM
(Last edited
12-06-2024
11:48 AM
by
SamsungJustin
) in
