Need picture of back of Model UN40D6300
(Topic created: 05-18-2021 11:53 AM)
userrrq8Qc4ucE
LED and OLED TVs
Web search indicates there are 4 HDMI ports, but my TV was bought in 2011 and looks like it only has one.  The manuals do not show the ports or give a good explanation of them.
Where can I find this information? Have they changed the number of ports on this model since 2011?
userrrq8Qc4ucE
LED and OLED TVs
Sent you the info and the manual does show it has 4 HDMI ports but some are labeled USB and show as USB on the Samsung menu. Have ordered a Roku firestick and will see if I can access the current Netflix app that way since it cannot be loaded on my old TV.  Thanks for your help.
SamsungJam
LED and OLED TVs
Samsung UN55D6300, UN46D6300, UN40D6300 Inputs - Picture Gallery
The model will have 4 ports on the left hand side this is at least the case with the US models.  If you provide the full model of your television I could see if your specific model could be one from a particular retailer.
userrrq8Qc4ucE
LED and OLED TVs
Not applicable
LED and OLED TVs
You are most welcome.
