TV not powering on
(Topic created: 02-19-2023 01:55 PM)
Vpmb7mm2746
LED and OLED TVs
My TV won't cut on I have a red light flashing. And no sound or picture just a blue line at the bottom of the screen. I have called the store to have it repaired three times since my purchase. The store has canceled my 5 yr warranty, and it's only been two years. Because of the number of repairs and the cost. I talked to a Samsung representative that told me she would have a supervisor call me back. I have not heard from anyone. Does anyone from Samsung monitor this chat?
Samsung_Moderator
LED and OLED TVs
Hello! Thank you for reaching out! I can see how this can be frustrating with your TV not powering on. I would recommend trying the troubleshooting steps in the following link: https://www.samsung.com/us/support/troubleshooting/TSG01001086/#tv-s-red-standby-light-is-blinking.
If this does not help then this will require service. Depending on your warranty you will have a few options for service.
- If your unit was recently purchased, you can check with your retailer on their return/exchange processes.
- If you have an extended warranty you can reach out to them to have service set up.
- If you're within the one year warranty, you can Private message me or one of our moderators or you can call in directly at 1-800- 726-7864 with your full model and serial number to have service setup
- If you're OUT of warranty, you can use this link below to find a service center in your area.
https://www.samsung.com/us/support/service/locations/
1 Reply
Samsung_Moderator
LED and OLED TVs
