No network + Error code 2014506-1
(Topic created: 09-09-2024 04:18 PM)
curiousblackcat
LED and OLED TVs
TV Model: UN50TU700DF
Model Code: UN50TU700DFXZA
Several days ago, my TV stopped connecting to my WiFi network and couldn't even find any WiFi networks to connect. It wasn't an issue with my internet (all other devices connected and worked).
I unplugged and restarted both my router and TV, didn't work. I reset network settings, didn't work. I did a factory reset, didn't work. I then bought an ethernet cable to connect with my router, and it keeps saying "No network cable found." A YouTube video suggested to unplug the TV for a significant period of time (overnight if possible), which then registered my wired connection.
When I tried to download the Terms of Service and Privacy Policy, there was a pop-up that said Model ID and version are not valid (error code 2014506-1). I turned off my TV and turned it back on, and now I've lost my network connection again.
Has anyone had this issue/know of any fixes? I feel like I've tried almost everything at this point.
Edited to add: I've also tried changing the DNS to 8.8.8.8, and it didn't work either. Running self diagnosis didn't help -- it says everything is good.
Samsung_Moderator
LED and OLED TVs
Hey, welcome to the community! When my internet doesn't work with any device, it upsets me to my core. Let's get yours right for you as soon as possible!
Looks like you've tried most of the troubleshooting related to this. There may be some extra steps here you haven't tried:
https://www.samsung.com/us/support/troubleshooting/TSG01111046/
If this does not help I recommend letting a service technician have a look. As we would like to gather additional information and look at this from a case-by-case basis, please provide the full model code and serial number of the device as well as your best contact phone number, name, and email.
Send a message on Facebook
Send Message on Twitter
Send Message to Moderator
If your unit is out of warranty and you would like to receive quotes on service/labor from an Authorized Service Center near you, please visit:
http://www.samsung.com/us/support/service/location
1 Reply
Samsung_Moderator
LED and OLED TVs
