Problem with Hulu Update
(Topic created: 08-12-2024 10:58 AM)
MG311
LED and OLED TVs
For the past few weeks I've been unable to watch Hulu on my Samsung smart tv model UN32M5300. It says update available, please install, but there's no way to manually install an update. The updates are supposed to be automatically installed. I spent two hours chatting with a Hulu representative, tried every possible remedy to rectify the problem, and nothing worked. In the end I was informed by the rep that it was a technical issue between Hulu and Samsung that the technicians were working on and it would be resolved soon. That was two weeks ago and there's been no change. The other streaming services I subscribe to--Netflix, Amazon, and Max--are working without a problem. Is there a fix for this on the way? If I can no longer watch Hulu programming on my tv when the app was pre-installed with the tv and therefore can't be deleted and re-installed, I might as well cancel the subscription. I would prefer not to, though.
JUMP TO SOLUTION
mbethf
LED and OLED TVs
Same issue.
Csweebraak
LED and OLED TVs
Same issue. Please fix
MG311
LED and OLED TVs
I just found a fix that actually worked for me.
1. Delete a few apps that you don't use.
2. Turn off the auto update setting.
3. Turn off the tv and then turn it back on.
4. Reinstall the Hulu app.
4. Open the Hulu app and log in.
Good luck!
MG311
LED and OLED TVs
I meant 5. Open the Hulu app...
You can reinstall without deleting the app. The reinstall is what seems to install the update.
TalonMan
LED and OLED TVs
MG311 - you deserve a cookie!! THANK YOU!!!!!!!
TJStream1-2
LED and OLED TVs
This worked for me. I had to delete some apps I don’t use. I assume the TV didn’t have enough storage for the update. I didn’t realize I had so many apps that I have opened in forever. Thank you!
VW916
LED and OLED TVs
We had to delete probably 10 apps that we don't use and were able to get the reinstall to finally work. Thank you MG311.
11942718
LED and OLED TVs
@MG311 thank you thank you thank you it worked! I deleted several apps that I did not use and it allowed me to reinstall on my Samsung TV
Katikat27
LED and OLED TVs
My Fandango at home app quit working three days ago. And I don’t see where I Where remove it and reinstall it and I don’t get it because it works on my other TV, but not on the one in my bedroom
Emmmmkkk
LED and OLED TVs
I was having the same issue with Hulu and as some suggested, deleted unused apps and reinstalled Hulu and now it works! Thanks guys!
