Qled 8k and Xbox
(Topic created: 12-13-2024 09:25 AM)
m0ns73r123
Cosmic Ray
LED and OLED TVs
I have been having issues with my xbox series x and I have been getting a lower resolution for the television as I have been reduced to 720p for years now it's been happening on my other television as well. This problem has been constantly occurring as I have been throttled and my graphics issue has been bad. I can't use 8k tv and I have been not able to use this 4k settings issue for years on multiple Samsung televisions and I have no administrative person and no student account so this reason has been given to me but I don't understand what they have been talking about. I couldn't imagine the security breach it may have been trying to get my picture straight and I have been reduced to 720p on 8k tv so I have no idea what to do. Any advice you can give. Adt security services have been no help as well so I am lost im telling you. Give me a shout out and tell me how you fixed it in Samsung products in the past so I can get free from blocked and enjoy my family television.
JBTechfanatic
Black Hole
LED and OLED TVs
This will depend on your exact TV model. First, ensure your HDMI cable supports 4K at 120 fps. Then, locate the HDMI 2.1 port on your 8K TV; newer 8K TVs have all ports as 2.1, while older models may only have one. Once connected, go to your TV settings, find the HDMI input settings, and enable HDMI input Plus. Then, turn on game mode. Finally, adjust your Xbox's output settings to your desired settings (remember that the game must also support those settings). Another great and easy way to set up your TV is to do a manufacturer reset, plug in all your HDMI devices again, make sure you are in the HDMI 2.1 port with your Xbox, power on all your external sources like your Xbox, and go through the TV's setup as new with it connected to the internet. The TV will help set up everything properly.
Noobie
Comet
LED and OLED TVs
Make sure your HDMI cable supports the desired quality you want.
JBTechfanatic
Black Hole
LED and OLED TVs
m0ns73r123
Cosmic Ray
LED and OLED TVs
Thanks alot for the information because I seriously didn't know the difference between them and the hub doesn't have it marked as I have checked it multiple times. Just need to read the manual for it I suppose. Thanks.
JBTechfanatic
Black Hole
LED and OLED TVs
If you tell me your model i can tell you what hdmi port it's usually stamped game
