- Mute
‎03-06-2025
08:42 AM
(Last edited
2 weeks ago
by
SamsungMatt
) in
Hi, just bought an oled 65in S90DD tv. and I would like to know how to remove the channel info banner that pops up every time for about 2 seconds every time I change the channel while watching Samsung free channels. I contacted Samsung and the guys on the phone could not help, talking to someone in another country. Also I cannot cast pics from my phone to the TV while on the same Wifi. Any help would be appreciated.
Thanks
Solved! Go to Solution.
- Mute
‎03-09-2025 06:39 AM in
LED and OLED TVsThanks for the quick reply. Since you're using an Android device, there's a few different ways you can cast and mirror your phone to the TV. I'm providing a link below that has detailed information on all these different options, including how to use each of them. Please let us know if this helps.
- Mute
‎03-06-2025 10:59 AM in
LED and OLED TVsHello! Thank you for reaching out! Unfortunately, you can not remove that information. As for the casting issue, are you making sure that your phone and TV are on the same wifi band? As both on the 2.4GHz Wi-Fi band? Also, are you trying to use AirPlay or another casting option?
- Mute
‎03-06-2025 02:11 PM in
LED and OLED TVsCan I, at least reduce the time that is visible? Regarding casting, I have an android cell phone, not using AirPlay.
- Mute
