S90C and DU7200D Remote Conflicts
(Topic created: 09-02-2024 08:43 AM)
Hornydawg
LED and OLED TVs
I already have 77” S90C in my basement den and was considering adding a 65” DU7200D but was wondering if the 2 Samsung remotes would try to control the other Samsung TV?
Samsung_Moderator
LED and OLED TVs
Hello! Thank you for reaching out! Yes depending on the exact model and if it's a universal remote it will try and control the other. The best way around this is to you the SmartThings app and control the TV that way.
1 Reply
Samsung_Moderator
LED and OLED TVs
