Samsung Smart OLED TV Internet Viewing Bandwidth Adjust?
(Topic created: 10-30-2024 03:09 PM)
userGDErQ843L6
LED and OLED TVs
Hello:
Downloaded BritBox streaming app onto my Samsung Smart OLED TV.  Britbox does not provide a means to adjust the streaming movie's Internet viewing speed or bandwidth.
Question: Is there a Samsung Smart OLED TV setting for adjusting the incoming movie's viewing speed or bandwidth.  Example: Change 4K (Ultra HD) to standard HD.
Thank you.
user_ams007
Planetary Samsung Care Ambassador
LED and OLED TVs
Unfortunately, I don't believe so, I checked my TV, and I have no options to tweak the application's picture, even if I change the picture processing from Film mode
JollyCello
Galaxy
LED and OLED TVs
@userGDErQ843L6  to the best of my knowledge on TV's and streaming devices this is not possible that are 4k. You can purchase 1080p streaming devices such as a Fire TV lite or the Google 1080 P.
The one from Google is $29!
user_ams007
LED and OLED TVs
When you install an app on your TV, the TV automatically optimizes the application to run at the best quality, You can try checking The Settings menu within the Application if they are available. As for adjusting the 4k settings that can be changed in the Settings menu on your TV, I am sure what model Oled TV you have, Those settings are located in the Picture menu/Expert Settings,
userGDErQ843L6
LED and OLED TVs
Good day "amsoo7":
Thank you for the inputs to my posted question. The Samsung TV being referenced is a "43" Class Q60A 4K Smart TV (2021)."  Your instructions regarding Samsung's TV Settings menu have been enacted.  Unfortunately under "Picture menu/Expert Settings", there is not an option for adjusting streaming movie picture quality as "the TV automatically optimizes the application to run at the best quality."  Does this mean this particular Samsung TV does not allow adjustments to its automatic picture optimization process or is does an adjustment capability found elsewhere within its programing?
Kind regards,
user_ams007
LED and OLED TVs
I believe that the application is automatically optimized by the TV, Some apps have an option within them to adjust some settings, but most of the picture processing is done automatically via the TV. I was able to find a Reddit Sub that deals with Britbox on Samsung TVs, Maybe this will help you tweak the settings for a better picture,
https://www.reddit.com/r/BritBox/comments/1d5ybzj/app_issues_on_samsung_tv/
userGDErQ843L6
LED and OLED TVs
Good day "amsoo7":
Thank you for the previous post.  I'm assuming the "Q60A 4K Smart TV" does not provide a user's means of adjusting or bypassing its streaming picture automatic optimization process.  If this is true, please close this inquiry.
I appreciate your efforts-Thanks.
Kind regards,
user_ams007
LED and OLED TVs
userGDErQ843L6
LED and OLED TVs
Hello "ams007":
Thank you for the assistance.  You are a kind person.
Kind regards.
user_ams007
LED and OLED TVs
It's my pleasure, Please feel free to reach out with any questions or concerns, Thanks for being part of the Samsung community. Your post may help someone else
