Sunnyaneel
- Mute
07-20-2024 10:26 PM in
LED and OLED TVsHello. I recently bought Samsung @CU7000 smart tv and the Samsung tv plus app is not showing and I couldn't find it in the apps as well to download. Moreover a lot of other apps that I could see in the Samsung website are not available or it could not find in the apps.
Solved! Go to Solution.
MrGhoul
Black Hole
- Mute
07-21-2024 12:37 AM in
LED and OLED TVs
Try this! Also, make sure you have a stable internet connection and check TV for updates.
1 Reply
MrGhoul
Black Hole
- Mute
LED and OLED TVs
