- Mute
08-04-2024
07:39 AM
(Last edited
08-15-2024
09:23 AM
by
SamsungCaleb
) in
Hello,
I have a CU7000B TV using a MZeibo soundbar. Whenever I am watching anything, if there is a moment where there is no or very low audio, the soundbar will completely cut out, which leads to the next audio being clipped off. My soundbar is connected via optical cable. Is there a fix for this?
Thank you!
Solved! Go to Solution.
- Mute
08-04-2024 09:51 AM in
LED and OLED TVsHello! Thank you for reaching out! I would recommend reaching out to MZeibo for support as this seems like it would be an issue with the soundbar.
- Mute
