TV wall mount
(Topic created: 02-10-2025 11:10 AM)
DKelly4492
LED and OLED TVs
I just purchased a 65"  OLED am I cant seem to find a wall mount that works with it. The TV has weight but is thin .
GaryB82
Galactic Samsung Care Ambassador
LED and OLED TVs
Ok found that one it says this Weight
Set Weight without Stand (lb)
46.7
Set Weight with Stand (lb)
49.6
Vesa 300x200
I use this one works great
https://a.co/d/1KhnCjm
If you've found my post to be helpful, Please like my Comments ✓✓✓.
If my response resolved your issue, please press the Like and ✓✓✓ to Accept as Solution button.
GaryB82
LED and OLED TVs
Whats the model number of the TV
DKelly4492
LED and OLED TVs
QN65SN0DDF
thank you
GaryB82
LED and OLED TVs
For some reason I can't find that model listed but still searching
edit
Are you sure its QN65SN0DDF
DKelly4492
LED and OLED TVs
QN65S90DDF
Try this , sorry
GaryB82
LED and OLED TVs
46.7
49.6
Vesa 300x200
Naustixx
LED and OLED TVs
Hang it like a picture 2 screws on the back
