TV wont stay on.
(Topic created: 02-13-2025 01:02 PM)
donharris25
LED and OLED TVs
TV wont stay on. It will come on for about 2 seconds then off. It will repeat that cycle every few seconds until unplugged  I tried the unplugging and that did nothing.
GaryB82
Galactic Samsung Care Ambassador
LED and OLED TVs
Sounds like something has went bad inside the TV and you would need to contact a service center to have it checked out.
https://www.samsung.com/us/support/service/locations/
If you've found my post to be helpful, Please like my Comments ✓✓✓.
If my response resolved your issue, please press the Like and ✓✓✓ to Accept as Solution button.
GaryB82
LED and OLED TVs
sassybizness
LED and OLED TVs
This happened to my TV 2 weeks ago for about an hour. Working fine since.
donharris25
LED and OLED TVs
Did you just unplug and then plug in to get the picture back?
donharris25
LED and OLED TVs
yes nothing just the same thing, on off, on off
Samsung_Moderator
LED and OLED TVs
Hey @donharris25! @GaryB82 hit the nail on the head this does sound like service would be the next step, but I do have a question for you. You mentioned that you had tried unplugging and plugging the television back in, but have you tried plugging the television into a wall outlet directly without a surge protector?  That's something that I've seen as an issue a few times.  If that doesn't help, you'll need to follow the link that @GaryB82 left earlier to find a service technician in your area.
