- Mute
01-25-2025 10:12 PM in
LED and OLED TVsHi, Can you please tell me what the VESA spec is for the VESA SPEC for Samsung Model # UN55RU7100?
Thanks, Scott
Solved! Go to Solution.
- Mute
01-25-2025 10:25 PM in
LED and OLED TVsI selected specs and it shows the vesa is 200x200
If you've found my post to be helpful, Please like my Comments ✓✓✓.
If my response resolved your issue, please press the Like and ✓✓✓ to Accept as Solution button.
- Mute
- Mute
01-25-2025 11:09 PM in
LED and OLED TVsThank you so much for your quick/helpful/detailed response to my question, I really appreciate it! As this model is discontinued, can you recommend a model that would be equivalent? Just as an fyi the main thing that I care about is the picture quality. I want a picture that is crystal clear, bright, sharp (not blurry), stunning detail, colors that are very vibrant, etc. So please keep that in mind when making your recommendations. Also, I need a tv that is going to last a long time, and that is reliable (i.e. I never have to worry about it shutting down on me). Thanks so much!
- Mute
01-26-2025 04:30 AM in
LED and OLED TVsThat’s a hard question to answer since it depends upon your budget on what TV you can purchase.
