49inches monitor - CHG 90 - LAGGY (HELP!!!!)
(Topic created: 05-23-2019 10:27 AM)
KeithLuk
Monitors and Memory
i just recently receive the CHG 90 49inches monitor, from my friend. He bought it for less than a year from Best buy.
I realized that left size of screen is laggy, i feel its much slower movement when i move around the shortcut (shortcut like google chrome icon on desktop), but right side of the screen is completed fine.
If i move the shortcut to right side, it's as smooth as usually (i used 1920x1080 earlier 24inches, 4ms), but i move to left, it show the difference, it slow and little laggy.
Why my left side of screen is laggy, but right size is totally fine? please help 🙂 help!!!!!
I tried to disconnect all cable and reset as factory setting, i tried HDMI & display port as well.
(cpu7700,GTX1070,32gb ram)
JUMP TO SOLUTION
userOIzW4PBvWJ
Monitors and Memory
Gr8 Thank you! 😄
usere2QzR98WBn
Monitors and Memory
You are a Hero..... just inboxed mine and was about to box it back up ! Uninstalled the software .... bingo
