- Mute
Sunday (Last edited Sunday ) in
Monitors and MemoryI'm confused on location of LS34C502GANXZA Power LED, manual points to Samsung label at bottom center of screen which looks like it may light up.
In settings there are two mode - Working and Standby. Neither make a difference.
Today at Best Buy I looked at similar models and none of them light up either.
I did notice a small Blue LED next to the right arrow key, which appears to be effected by the LED setting in the set up menu
It is the same on my Monitor at home meaning small blue LED and effected by LED setting in Menu.
When I talked to Samsung last night for an hour they thought I should send it back for repairs, but know I think they do not even know where the POWER LED is located.
Manual shows the location of the Blue LED in Manual but does not say what it is.
Any Thoughts?
