M70B Monitor Won’t Power On – Logic Board Failure
(Topic created: 07-06-2025 03:22 PM)
userHHWithIbbb
Monitors and Memory
Model: LS32AM702UNXZA
This 32" Samsung M70B Smart Monitor is failing to power on. When plugged in, I hear a click from the mainboard, and when pressing the power button, the screen briefly flickers (like lightning), but no splash screen or boot occurs.
Through inspection, I’ve confirmed:
  • The LCD backlight works if disconnected from the mainboard.
  • All cables and external power are functioning.
  • Issue is likely related to logic board/firmware failure.
Looking at forums and Reddit, I see similar issues from other users involving sudden failure of these monitors — no physical damage, just a spontaneous failure of the internal board. This appears to be a systemic issue.
I’m requesting that Samsung investigate this as a potential latent defect and provide guidance or service support — even if out of warranty. This is a premium monitor and failure at this stage should not be acceptable.
LongHiker
Galactic Samsung Care Ambassador
Monitors and Memory
@userHHWithIbbb This is a user to user discussion group, it is not a direct contact to Samsung.
For immediate assistance, one option is to use the Samsung Members app -> Support -> Send text. This will open up live troubleshooting.
Another option is to contact Samsung support via https://www.samsung.com/us/support/contact/
1 Reply
LongHiker
Monitors and Memory
