Need replacement wall mount plate for Odyssey Ark monitor
(Topic created: 01-13-2023 07:15 AM)
DanBenZvi
Monitors and Memory
Need a replacement wall mount plate for the Odyssey Ark monitor.  Will pay whatever is necessary for it.
Samsung_Moderator
Monitors and Memory
Hello! Thank you for reaching out! We do have some wall monitor mounts on our website that you can purchase. Depending on what you need you should be able to find something. But here is one that we can recommend https://www.samsung.com/us/televisions-home-theater/television-home-theater-accessories/televisions/...
1 Reply
Samsung_Moderator
Monitors and Memory
