Odyssey G7 missing power chord
(Topic created: 06-27-2023 03:20 PM)
scheetztm
Monitors and Memory
Hello,
I recently transported my Odyssey G7 Curved 4k monitor from Samsung across the country and ended up losing the power chord in the process. I have purchased multiple replacement chargers that seemed to meet the specifications required for the monitor and none of them have worked. Is there any power supply I could purchase from you guys or a third party that would work for my specific monitor? This would be extremely helpful.
Samsung_Moderator
Monitors and Memory
Hello! Thank you for reaching out! The best place to go to will be samsungparts.com. You can go there and type in your specific model number to find your power cord. Please feel free to reach out if you have any questions!
1 Reply
Samsung_Moderator
Monitors and Memory
