Odyssey G7 white line on right side of monitor
(Topic created: 12-20-2021 10:06 PM)
user7gVgecCinp
Monitors and Memory
Just bought the monitor and I fired up Forza horizon 5 after setup and I saw this weird line on the right side of the monitor that is pretty distracting. I only see it when I'm in game. Is this normal? Pictures attached.
I have the 32 inch version and a 3080 to if that matters.
user7gVgecCinp
Monitors and Memory
Awesome I'll try this when I get home thanks so much!
Do you own this monitor by chance? I would love some personal input on the performance. I never owned a monitor as I was a console gamer for years. I was between this one or the LG 34gp950g but ultimately chose this one as it was 200 dollars off so the value seemed to be worth it.
Thanks again!
Big65
Cosmic Ray
Monitors and Memory
Go into monitor menu, display settings and adjust the horizontal setting to the right 2 clicks.
user7gVgecCinp
Monitors and Memory
Thanks again!
