- Mute
2 weeks ago in
Monitors and MemoryI bought a Samsung odyssey g70b 32' 144hz monitor last month and randomly it will switch from 144hz to 60hz, and only show options for refresh rates lower than 60hz until i restart my computer.
- Mute
Monday in
Monitors and MemoryHello, There. The hz the monitor shows is dependent on your external device's signal. The monitor only displays the signal received from whatever is connected to it. (i.e. Computer, roku, cable box, etc.)
I would recommend checking your computer or any external devices you may have connected to the unit. You'll need to check those settings, along with your graphics card, and make sure everything is up to date software-wise with your external device. Here's a link that can help: https://www.samsung.com/us/support/answer/ANS00085242
In addition, you can also check that the software is completely up to date on your unit by utilizing the following steps: https://www.samsung.com/us/support/answer/ANS00062224/
- Mute
Monday in
Monitors and MemoryEverything is up to date on both my computer and the monitor. It seems to happen after the monitor goes to sleep and wakes up. Switching Game Mode off and on also seems to help.
- Mute
Tuesday in
Monitors and MemoryI would recommend turning off game mode completely to see if this helps. Also, after looking around I was seeing other people have this issue but on a laptop and not on a Samsung based device this seems to be a some type of windows issue causing this to happen. From what I could find changing the power plan to performance should help. If it does not, I would recommend to also reach out to Microsoft support.
