- Mute
‎03-20-2024 12:43 PM (Last edited ‎03-24-2024 03:20 PM by SamsungChelsea ) in
Other Mobile DevicesPhone won't connect to wireless headphones
Solved! Go to Solution.
- Mute
‎03-22-2024 08:21 PM in
Other Mobile Devices- Mark as New
- Mute
‎03-20-2024 12:55 PM in
- Mute
‎03-20-2024 12:58 PM in
- Mute
‎03-22-2024 05:04 PM in
Other Mobile DevicesDo you have a watch, TV, or other BT device that you have previously connected the headphones to? BT devices tend to automatically reconnect to the last device they were connected to. So, if your headphones say they are connected, you have to figure out what they are connected to, then disconnect them from that device and connect them to the one you want.
- Mute
