Compatible box and cable for frame TV
(Topic created: 09-07-2024 06:58 PM)
Afm238
QLED and The Frame TVs
Hello,
I recently found a frame TV, model UE43LS003AU. I’m trying to figure out what model One Connect box and cable are compatible, so that I can buy them. It is not indicated anywhere in the documentation. Can someone point me in the right direction? Anything else I will need?
thanks
Samsung_Moderator
Hi @Afn238 and welcome to the community!  We are US based support so we wouldn't have the info available that you're needing, but don't fret!  If you fill out this form:
https://www.samsungspares.co.uk/general-enquiry/customer-services.pl
The team in your region will be able to provide you with the information for both the one connect box and the one connect cable.
Thank you for being a Samsung customer and don't hesitate to reach out if you have additional questions!
1 Reply
Samsung_Moderator
