Home button goes to art mode first not to smart hum or normal home area
(Topic created: 05-28-2025 07:51 AM)
Unclekeg
Cosmic Ray
QLED and The Frame TVs
Several months ago, my 2022 frame started to go to art mode when hitting home from passively displaying art.  It used to go to the main home area where I could see all of my apps etc. This may seem like a minor thing but it is been bugging me for months as it results in extra multiple button pushes to get to YouTube TV or another app. Anybody know what happened or how to fix this?
Unclekeg
Cosmic Ray
My solution was to start using the power button to wake from art mode.  Also double check your start screen setting in settings
nzbex
Hi - did you find a solution? Same problem here!
Unclekeg
Cosmic Ray
atomic-z
I've had this same annoyance. Seems counter intuitive that pressing the Home button doesn't take me to the Home screen. I have versions of this TV series and they behave differently. I really wish some of these buttons could be reprogrammed or a setting can be configured.
Johntomwer
Anyone get a fix to this? Driving me crazy
