Re: Accessibility shortcut also enables Voice Guide and Sign Language Guide
(Topic created: 05-10-2024 03:51 AM)
MrSTEVEBROWN2024
QLED and The Frame TVs
Looking for the feature that allows you to highlight a paragraph and it will read it to you
Samsung_Moderator
Hello! Thank you for reaching out! I could not find a feature such as this on our TV's. There are voice guides that will read what's on the screen, you can use the link below to help get this set up.
https://www.samsung.com/us/support/answer/ANS00088583/
1 Reply
Samsung_Moderator
