battery will not charge beyond 61% - Samsung A7 lite
(Topic created: 06-03-2024 11:43 AM)
ssss1234
Tablets
I just opened the Samsung A7 lite 32gb and it will not charge beyond 61%.
Under battery setting nothing is on to optimize batteries. I tried changing the setting to ON to see if it would even charge up to 85% but nothing.
Help?
GaryB82
Galactic Samsung Care Ambassador
Tablets
Sounds like a battery issue and would need to be tested at a service center to see what is causing the battery to not charge past 61% since they are no settings to block it from charging past that
https://www.samsung.com/us/support/service/locations/?product=N0003007
If you've found my post to be helpful, Please like my Comments ✓✓✓.
If my response resolved your issue, please press the Like and ✓✓✓ to Accept as Solution button.
GaryB82
Tablets
bill-e
Cosmic Samsung Care Ambassador
Tablets
My tablet charged weirdly for about a week after the 6.1 update but has since figured itself out and keeps my Tab at 80%
What I did, though I don't know if it helped, was to clear the system cache and power off and on the tablet.
I would either turn Battery Protection to OFF or as I did, turn it to ON and Maximum and then do the resets.
To clear the cache,
Turn off the device
* Connect to a computer via USB
Press and hold Volume Up + Power buttons simultaneously till the device logo appears
When it logo appears, release Power button but hold the others few more seconds
Release all the buttons when Recovery Mode screen appears
You can use the Volume Up and Volume Down buttons to scroll up or down, and the Power button to select
Using the Vol Down rocker, select Wipe Cache Partition
Press the Power button to select
Use the Vol Down button to select Repair Apps
Use the power button to select
Use the Vol Down button to select Restart
* Some devices need to be connected to a computer in order to enter the Recovery Mode.
** If my response helps, please click on Like (Heart). If I resolved your issue also please click on Accept as a Solution so that others can benefit.
Bill
Galaxy Fold 6 512g(VZW), Galaxy Book (original, VZW), Tab S8 Ultra, Tab S4, Galaxy Watch7Ultra(VZW),Galaxy Watch6Classic 47mm(VZW), M8 Smart Monitor, NEO 55" QN90D TV, Buds Pro
